Problem of measurering wrong resistance on DMM with scanner
Hello Mr Kazu
What is the present condition of your problem?Is it already solved?
If not yet, could you please inform me whether you tried my advice.I think mail from Mr Dennis may be also effective.I will  be grateful if you let me know about the present condition of your problem.
Thanks in advance.
saha | AE | National Instruments, Japan
Message 11 of 13
(693 Views)
Hello, K.Saha
The problem I had been troubled for a long time has been solved somehow.
I think your effective advice lead this result.
Thank you very much!
anyway, I have a question so Please help me to solve this problem.
I have programed Intensity Graph to show temperature distribution.
and There is color lamp with graph.
Color distribution shows blue of max. from red of min. (It is not min. and max in Z-scale of propety node)
so I want to change num to color of color lamp (In other words, blue of min and red of max.)
Thanks in advance.
Message 12 of 13
(685 Views)
Hello Mr Kazu
Its fine to hear that your problem is solved.Thanks a lot for the great news.
Its very easy to change the color regarding to the marker.Just right click on the marker (the number at the right side of the color lamp) , you want to change color. Then select marker color from the short-cut menu and you can easily set any color for that marker.
If you want to increase the number of markers on the color lamp, you can do it by right clicking on the color lamp(specifically at the point on the color lamp where you want to add a marker), and select "Add Marker".Thats all you have to do.
Try it and let me know if you have any other questions.
Thanks in advance.
Message 13 of 13
(678 Views)
