Problem on Concurrent access to MS Access Database by using DB connectivity Tool
Hey all,
I have 3 PCs run the same program to write data to database, but as you know, the database can only support one access at a time, so a crash will happen when there are above 2 PCs get into the database at the same time. Is there any suggestion to deal with this problem?
Thank all you guys.
(2,763 Views)
Try adding this to your connection string:
;Mode=Share Deny None;
(2,751 Views)
