Problem printing to PDF
I've tried a few different 3rd party programs to print to PDF, but keep getting errors. The goal is to print the .vi Front Panel to a programmatically determined file. Screen shots fo the errors are attached.
I've tried Bullzip:
https://decibel.ni.com/content/docs/DOC-22555#comment-27786
Error 1172
And Exaprom:
https://decibel.ni.com/content/docs/DOC-10952
Error 1386
And PDF Creator:
https://decibel.ni.com/content/docs/DOC-4552
Error -2147221164
I've tried reinstalling the programs, the pdf creators, and the .NET framework, but I feel I'm missing something.
I'm using LV 2014 on Windows 8.1.
Thank you!
Message 1 of 10
(11,369 Views)
Do you only see these problems when printing from LV? Or does any attempt to print generate errors?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 10
(11,310 Views)
I only have the problem in Labview. I'm able to use any of the PDF printers when using other applications.
Message 3 of 10
(11,299 Views)
OK, if you manually print (no code) does that work?
Mike...
LabVIEW Champion
Message 4 of 10
(11,280 Views)
Yes
Message 5 of 10
(11,276 Views)
Accepted by topic author COIEngineer
Hi COIEngineer,
I installed and opened the BullPrint Example and was able to duplicate the error you are recieving when I pointed it to a .vi file directly, but was able to get it to successfully print when pointed to an image file. Could you possibly print to a jpg, print that file to a pdf, and then delete the original(if you don't want the original file).
That error is generated when the pdf printer is unsure how to handle printing the file type specified.
Tanner B.
Systems R&D Engineer - Aerospace, Defense, and Government
Message 6 of 10
(11,223 Views)
With Exaprom, you need to unlock the DLL. Right click on the DLL and select Unblock.
For me, the option to unblock wasn't available.  This from a stackoverflow post helped:
"I've often ran into this same problem when downloading files. Windows-7 will not always display the unblock button. Here are a couple easy workarounds:
First to verify the file is actually blocked, open a command prompt and type:
more < yourFile.exe:Zone.Identifer
If it reports your file has a ZoneId = 3 or 4, your file is indeed blocked. You have two easy options to unblock it:
First Method: If you have PowerShell version 3 or higher, you can open a PowerShell window and type:
C:\>Unblock-File -Path C:\Path\ToFile\yourFile.exe
To open a PowerShell window type powershell into the run box. To check your PowerShell version, type this from the PowerShell prompt:
C:\> $PSVersionTable.PSVersion
Second Method: If you don't have that version of PowerShell installed, you could install it for free but there is a much faster download. Download the free streams program from sysinternals:http://technet.microsoft.com/en-us/sysinternals/bb897440.aspx and from a command prompt type:
streams -d C:\Path\ToFile\yourFile.exe."
Message 7 of 10
(11,215 Views)
Double post from slow internet speeds today and me being impaitent...
Message 8 of 10
(11,214 Views)
@Tanner! wrote:
Hi COIEngineer,
Thank you!! This is a functional workaround. For reference, it also does not know what to do with .png files.
Message 9 of 10
(11,204 Views)
This solved the problem with Exaprom, and produces a nicer image than having to convert from jpg. I unblocked the .DLL, restarted Labview, and it worked. Thank you for your help!
Message 10 of 10
(11,199 Views)
