Trying change duty cycle in "Simulate Signal"
Anyone knows why I can't change the duty cycle in Simulate Signal? This option appears unavailable for me. How I can access this option? I need generate a wave triangular assymmetric.
Thanks.
(3,037 Views)
The option is not available with the Express VI. For different rise and fall times, I would just use two different ramp pattern functions and concatenate the two arrays.
(3,029 Views)
The dutiy cycle is only for square waves, i.e. a signal that only has two possible states (on or off). The duty cycle defines the percentage of the time the signal is on during each interval.
In any of the other signal shapes, the amplitude is variable and the concept of a "duty cycle" makes no sense..
(3,008 Views)
