Problem reading from RS-232 Device by Visa Read when runnig the Reading VI as a sub.vi
Hi fellows
Igot a VI, with a VISA serial write Icon and a VISA serial read.
I write a command to the device at com port with the VISA write icon and expecting to get an OK as response from the device. Then I read from the device, By using the VISA read Icon. to ensure the 'OK' response from Device was. So when I run the Vi, all thing work. But when I run the Vi as a sub vi, I can only detect that the VISA write is running, but not the Visa read. I can see this by looking at the Bytes at port before the VISA read. Its ZERO.
three pics are attached
Regards
HFZ
HFZ
(2,789 Views)
Hi HFZ,
perhaps this is because you are not using the VISA-close.vi in addition to the VISA-open.vi in the sub-vi.
Therefore running the sub.vi in your main-vi's while-loop whitout calling VISA-close can result in a problem.
Please try using the VISA-open.vi previous to your while-loop and remove it from your sub.vi.
 Andi
~~~ Logic is a systematic method of coming to the wrong conclusion with confidence ~~~
(2,773 Views)
I would also suggest you stick a few probes on the error wires and the VISA resource name to verify that you passed it to the subVI.
(2,751 Views)
