Problem regarding bode plot of higher order system
I want bode plot of very higher order system in labview. But it always shows the error "Analysis:  Input parameters has at least one element that is Inf, NaN, DBL_MAX, or DBL_MIN".
Give me some solution of it.
Message 1 of 15
(3,943 Views)
Hi tanu,
well, the solution to that error message would be to filter out those "wrong" input parameters...
Message 2 of 15
(3,931 Views)
How could I filter out those input. I have 592 order system.If give some example it will be helpful.
Message 3 of 15
(3,927 Views)
It shows "Error -20068 occurred at NI_LinSys_LinSys Conversion.lvlib:CD Convert TF to ZPK (LinSys).vi".
Message 4 of 15
(3,924 Views)
Hi tanu,
usually the OP is supplying an example VI with typical data so others can reproduce the problem...
(Mind my signature.)
Message 5 of 15
(3,922 Views)
Please let me clear about OP.I couldn't understand.Can you give one example?
Message 6 of 15
(3,913 Views)
Hi tanu,
OP = original poster (means: you!)
You have to provide an example, which illustrates the problem you want to solve!
Message 7 of 15
(3,910 Views)
I have attached one example.
Message 8 of 15
(3,905 Views)
Hi tanu,
you didn't mind my signature as requested in message #5...
Message 9 of 15
(3,899 Views)
Sorry, about which signature? I have already given my example, where the error occurred. So give the solution kindly.
Message 10 of 15
(3,870 Views)
