print pdf
Hello!!!!
This part of the Main Opens a file in pdf format and releases the image of the front panel. When it opens (creates) the pdf file , asks you the name of the file ... how do I preset the file name without leaving the user to enter the name and automatically save it to a folder on my pc? Any ideas?? thanks!!!
(3,210 Views)
let's see if I correctly understood what you are trying to do: you are retrieving the image of the front panel and appending it to a new pdf file (thus, you are printing the front panel to a pdf file). When the pdf file is created, you would like to avoid to display the dialog box to ask the name of the file to save but you would need the file to be automatically saved without prompting to the user. Am I correct?
Are the pdf subVIs you are using based on some pdf printer tool (such as PDFCreator)?
Bye!
Licia
(3,149 Views)
