Problem remote connection to SQL via ODBC
Hello, I have a server machine on which I installed the "SQL Server 2008 R2 Express." On the same machine I have configured a connection to the SQL server via ODBC and I developed a VI that uses the "LABSQL ADO function" and it perfectly communicates via ODBC with the database.
The problem is when I try to connect to the database from a remote PC. Even on the remote PC I configured the connection via ODBC. I launch the same VI I described above, it performs correctly the ADO Connection Open the ADO connection, but the SQL Execute returned an unknown error: -2147217865. It seems that it can not find the table on which I am doing the query.
Does anyone have any idea? I have no experience with databases and do not know what tests to do.
Thanks a lot.
(2,653 Views)
actually the Microsoft error code seems to be related to not-existing table (see here).
Anyway, this error code may result when trying to use tables with spaces or other special characters ("-", "/", "\", "?" ) in their names.
Is this true also in the database you are using?
Could it be an issue with permission levels?
I hope it helps!
Bye,
Licia
(2,624 Views)
