labview program is not responding in middle of running
I 'am attaching the front panel bmp file .This shows the program become passive in between the run of it. So please help me to overcome this problem
(2,523 Views)
First of all, you didn't attach anything.  Secondly, the front panel isn't going to help us debug your code.  Attach the actual VI and tell us what you did to make your VI "freeze".
(2,520 Views)
I dont think that this middle, last or first is posing problem. Post your VI that will explain the reason.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,508 Views)
