Problem selecting cursor point plot
Thanks for trying. Obviously there is a bug in a shared component of the inner NI code. Hopfully it will be easy to fix.
Message 11 of 14
(1,776 Views)
That boolean is true when we click on the plot area and false if we click on rest of the graph.
Message 12 of 14
(1,774 Views)
Thanks. I have not tried and the help page does not mention this. 😉
(The help for the sister method just says "returns true"... would be nice if it would return FALSE if the point is outside the visible area, maybe it does? :D)
Message 13 of 14
(1,765 Views)
Hello, sorry to revive the thread but I was wondering about if the issue was fixed, I developed an application to inspect data and it uses a lot of graphs, XY and Waveform Graphs, but the users reported me that sometimes they cannot select the cursor at all, after reviewing it it seems happening only when the difference in axis Y Min Max is too low or high.
I followed the threads in Monthly bugs but I did not see a filled CAR.
Message 14 of 14
(1,196 Views)
