Problem setting cursor X position using Property Node
I have two waveform graphs that each have a cursor.  I also have an event structor that have an event case triggered by "cursor release" in the first waveform graph.  When the cursor release occurs, the cursor X position "Cursor.PosX" is read from the first waveform graph using a property node, then this value is assigned to the Cursor.PosX for for the 2nd waveform graphy.  So it moves that cursor to the same position of the cursor in the first waveform graph.  However everytime I move the cursor the position moves but not to the right position.  It is always close but not exact.  If I move cursor in waveform 1 to 6.74e-6, then the cursor in the waveform 2 moves to 6.73e-6.  Sometimes it is the same, and sometimes it is off by 0.01e-6 or 0.02e-6.  Both waveforms have the same # of points and the exact same X data.  Thanks for any help.
Message 1 of 14
(13,133 Views)
What version of LabVIEW are you running?
Kareem W.
Web Product Manager
Message 2 of 14
(13,091 Views)
Are the cursors free or locked to a plot?
Could you attach a simple example that demonstrates the issues?
Message 3 of 14
(13,088 Views)
It is 2010.
Message 4 of 14
(13,077 Views)
They are locked to the plot.
Message 5 of 14
(13,076 Views)
Do both plots have exactly the same xo and dx?
Message 6 of 14
(13,068 Views)
This isn't exactly what I have, but it shows what I am talking about.  I have two waveforms with the exact same dt and the same number of Y points.  Yet when I read one cursor and try to force the other one to the same X position it won't work.  It is close, but not the same.  Thanks for any help.
Message 7 of 14
(13,062 Views)
Accepted by topic author lme999
I think the problem is caused by the fact that you plot a huge number of points per screen pixel, and since the axes are different, things get rounded differently. (This might be a bug, though). Note that If you show the data less dense (e.g. set the two x scale for 0 .. 0.1, your method works fine).
As a workaround use "cursor index" instead of "cursor position x". This gives you the index of the array point linked to the cursor and will be exact in all cases.
Message 8 of 14
(13,056 Views)
Thanks.  That works much better.  In my applications the X axis is always the exact same, but the Y axis is different, so I have no idea why the position doesn't work.  You are probably correct that it is some rounding issue of some kind.
Message 9 of 14
(13,037 Views)
hi,i want that the black ball pass by the same position of the 6 cursors on xy gragh ,i can't arrive to determine the right position of cursors
Message 10 of 14
(12,700 Views)
