Problem setting cursor X position using Property Node
hi,i want that the black ball pass by the same position of the 6 cursors on xy gragh ,i can't arrive to determine the right position of cursors
Message 11 of 14
(1,948 Views)
Message 12 of 14
(1,948 Views)
hi
i need somebody to help me urgently
in my vi which is attached,i will set the position of 6 cursors on xygraph ,then a ball most be after 200ms on cursorposition0,then cursorposition1......................then cursorposition5 but on other xygraph
how i can do this
Message 13 of 14
(1,948 Views)
You now posted the same VI nine (!!!) times in a row (also here) in threads that are already marked as solved.
Please start a new thread and post the code only exactly once. everything else is redundant. Thanks!
Message 14 of 14
(1,945 Views)
