Problem to install modul SCXI 1112 with a 1000DC chassis
I want to install the module SCXi 1112 with the chassis 1000DC but when I test the chassis with NI Max, it don t find the module.I connect the chassis to a MIO 6025E. One precision, I have control the connection between the two elements and the autodetection don t find the module
warning message Failed to find Slot 1 is empty
(2,390 Views)
Mous,
The first step is to make sure that the NI-DAQ driver is installed properly and that your DAQ board (6025E) is working properly.
Then, refer to page 2-6 and 2-7 of the SCXI 1112 User Manual. It gives some troubleshooting help for the error you are receiving.
http://www.ni.com/pdf/manuals/322476a.pdf.
You may also want to try installing the 2 modules separately and install them in different slots to rule out which module or slot is causing a problem.
Hope this helps. Have a great day!
(2,390 Views)
