Problem while capturing miliseconds value in particular test condition using CDAQ
Hi all
      I have an application which is using to capture and storing analog value (1000 datas for sec) and storing an value in text file when the pulse input is captured(analog value go to max ).The pulse input duration min is 1 miliseconds.
While trying to do the above storing the value is not stored in notepad..
(2,260 Views)
Hi kps,
Then you made something wrong!
Some comments:
  • I would not store data in "Notepad", but in text files on my harddrive.
  • When you have problems with your code you should attach your code (but not just images of code)…
(2,254 Views)
Thanks for the reply
      Actually  I was store in .txt format only, What happened means initially when I did that project that was working and data also stored in Text file. Now  that project pc is updated with windows 10(from windows 7) .
I don't understand why the same application is not working similarly
(2,227 Views)
Accepted by kps001
Hi kps,
Well, I guess something changed in this whole setup - like the OS which is used to run your executable!
You (should) know the code, so you can debug it!
(2,221 Views)
Did I read correctly that you're trying to capture a 1 ms pulse while sampling at a rate of 1 sample/ms? You should be sampling at a higher rate. In any event share your code and perhaps you will get better help. I have some guesses about what might be going on, but to see your code would help to narrow down those guesses.
(2,194 Views)
Solved...
Actual Problem is Compatibility issue
Thank You all for your supports😍
(2,139 Views)
