Problem whit istallation of LabVIEW2009 trial version, HELP ME SOON!!!
I've a problem with istallation of labview 2009 trial version. I have download all and also two months ago I have used it and it's ok, but now, when I prove to istall it, it seems that it is ok, but after I can't find labview.exe. How can i solve this problem?
Please respond soon.
Message 1 of 13
(3,174 Views)
Are you saying you are able to install it but not able to launch labVIEW? Is the trial period over?
Message 2 of 13
(3,159 Views)
I have used Labview 2009, trial version, 2 months ago and I've finisched trial period. Now I have re-istalled labview2009. It's it possibile to use it for an other month? Thanks.
Message 3 of 13
(3,156 Views)
No you cant use it beyond the trial period.
Message 4 of 13
(3,151 Views)
Hi Michelle1892773,
call your local NI office, they can help you.
Mike
Message 5 of 13
(3,149 Views)
But I have disistalled and istalled it again. This way is not good?
Message 6 of 13
(3,136 Views)
NO!!!. IT wont work that way. I suppose Ni rep also might not be of much help actually
Message 7 of 13
(3,128 Views)
No, it is not good. The license manager tracks how long you were using it and disables it after the trial period. If it were as simple as uninstalling, everyone would be running LabVIEW for free.
Message 8 of 13
(3,126 Views)
You can't cheat the LabVIEW installation by re-installing it.  Once the trial period has started, it continues to countdown from the original date when the trial period began.  No matter how often you uninstall and reinstall.
The only (legal) way around that would be to try a newer version..  Or if you can find older versions, you can try those also.  All limited to 30 days.  And this limitation applies to any executable you might build, as the run-time engine is what gets limited by the trial period.
Message 9 of 13
(3,123 Views)
Where Can I find version 8, please?
Message 10 of 13
(3,110 Views)
