Problem with 2nd Monitor settings
Hello All,
I did step up the monitors as in attached image. When I start LabVIEW, it always starts in second monitor.
I have some dialogs in my application and if I set the "window Run -Time Position" as in attached image, but still my dialog boxes are going to bottom of the second monitor.
Could anybody please let me know, why?
Message 1 of 8
(4,569 Views)
I think you should set the Monitor to '1' or '2' in the VI properties.
I think Primary is the active monitor with the current open panel.
Ton
My LabVIEW Ideas
Message 2 of 8
(4,554 Views)
Thanks for the reply.
I tried that too but it did not work.
I did run application in monitor one and when I call, dialog it is going to bottom of the second monitor. It has to be in same monitor.
In my dialog, I even set the monitor property to "1".
If I keep the monitors side by side in settings, it works fine. The problem is coming only when I set monitors as in attached image.
Message 3 of 8
(4,552 Views)
Try making the top monitor number 1 if you can do this in windows.
- tbob
Inventor of the WORM Global
Message 4 of 8
(4,526 Views)
It works if I make top monitor to "1".
But for our TestStands we need top monitor to be "2".
Message 5 of 8
(4,523 Views)
And what about moving the dialog yourself (in code I mean), it's not the easiest way, but not really hard.
For bug checking, how does the dialog behave if you set the screens next to each other?
Ton
My LabVIEW Ideas
Message 6 of 8
(4,494 Views)
if I set the monitor settings side by side, then all my dialogs are behaving as expected.
If I control programmatically then I need to take care about all monitor resolutions. This will be a big pain.
I am not getting why it behaves if I set the monitors  as in attached image.
Message 7 of 8
(4,488 Views)
I think this is a genuine bug in LabVIEW.
I'll put it in the bug-thread.
Ton
My LabVIEW Ideas
Message 8 of 8
(4,481 Views)
