Problem with Agilent 82357B GPIB
I have installed the keysight I/O libraries and this interface does recognize an instrument.
I have noted that the interface is working properly when viewed in control panel.
The problem I'm having is I cannot see (or create) the interface in MAX?
Any suggestions?
Thank you
(1,559 Views)
Have you tried "scan for instruments"?
GPIB Instrument Control Tutorial - NI
(1,545 Views)
Accepted by LED47
In NI-MAX, under NI-VISA --> VISA Options --> General Settings you will see Passports.  Make sure that the appropriate ones are checked.  (Tulip comes to mind but it seems it is 32-bit only.)
Bill
CLD
(Mid-Level minion.)
(1,538 Views)
No I haven't we have to go back a step further I'm unable to see the interface and MAX
(1,536 Views)
Yes that worked thank you
(1,535 Views)
It killed me once and I never forgot the lesson.  😉
Bill
CLD
(Mid-Level minion.)
(1,500 Views)
