07-16-2004 01:44 PM
07-22-2004 11:36 AM
07-23-2004 01:48 PM
07-28-2004
11:06 AM
- last edited on
08-24-2026
09:07 AM
by
Content Cleaner
ATC Herman,
Based on the picture you posted and what you are describing, it looks like you might have an incomplete install. What version of the toolkit do you have? Was it first installed on an earlier version of LabVIEW, or did you install it first on 7.0? Your VI Documentation Palette appears the same as if you hadn�t installed the toolkit. I�ve attached a screenshot of what it should look like. The VI in question is a polymorphic VI, which may be causing some of the confusion. If you right-click on it and select �Open Polymorphic VI�, it will show you what options you have, depending on the input. I opened both test and test1, and they appeared the same for me. I was able to have them both on the block diagram. The path to bo
th of them was C:\Program Files\National Instruments\LabVIEW 7.0\vi.lib\printing\ReportDocExtensions.llb\Append Front Panel Image to Report.vi. The .llb ReportDocExtensions has the polymorphic VI, as well as copies of each of the possible instantiations. Make sure you have these VI�s in the .llb in that directory.
Please let me know if you are able to get to the bottom of the issue with the above information.
Thanks, and have a happy day!
Robert M
Applications Engineer
07-30-2004 02:23 PM
08-04-2004 09:16 AM
