Problem with Automation Open after installing new modules
I am using Matlab COM object in my Labview application. Yesterday everything worked fine. In meantime, I installed Real Time module, Data Logging & Supervisory module and Compact Vision. Today I found that I cannot run Labview application. This is message:
Error -2147221164 occurred at Automation Open
This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input.
In the list of ActiveX controls, everything is the same as before.
I am using XP SP2 and firewall is disabled.
Regards, Edin
Message 1 of 1
(2,553 Views)
