Problem with Build Spec in project explorer
I have LabView Professional Development System.  I am using DAQmx with a USB 6221.  I need to include the nilvaiu.dll in an installer I am trying to create.  However, I can not get this dll to appear in the 'Preview' screen when I create setup the build spec to create an executable (before creating an installer).  The lvanlys.dll does appear.  Both the dll's are in the 'dependencies' section of the project.
Can you help me?
(3,517 Views)
That is part of DAQmx so you just have to include DAQmx as one of the additional installers. With DAQmx, you have the option to have a full install or different run-time versions. You also have the option to include MAX and the hardware configuration stored in MAX.
(3,503 Views)
Thanks.  I have built the installer.  But the file is so large I am still waiting for it to install on the target PC.  I will let you know how it goes tomorrow.  Never thought I would use a thumb drive with more than 1GB but the final installer was 865MB.  Is that right?
(3,496 Views)
I think that is about right if you install the full version of DAQmx. I'm using the runtime 4 along with MAX and NI-VISA runtime and my installer is about 360 MB.
(3,491 Views)
