Reading a remote control from Labview
I have an application where I need to control a LabVIEW application running on a PXI using an industrial remote control.  Does anybody ever used or saw one (usb, bluetooth, etc..)?
In fact, it is not really a LabVIEW question, I'm only looking for the hardware (the remote control).
Patrick
(4,083 Views)
Hi Patrick,
Thanks for the post.
I had noticed you've not received any support thus far.
Im afraid I have not heard or seen an industrial remote control, you could please provide some more details of such a device?
Kind Regards,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(4,053 Views)
Hello Hillman,
I've done a lot of reseach on the web and found almost nothing except this one, which is not that much industrial.  It come with a IR-Serial interface that ou can connect to your computer or PXI. (http://www.remotefactory.com/2a2.htm).
You can also use a universal remote or even a Wii remote if you are ready writing your onw driver.  However, you don't look really serious in front of your customer!!!
Patrick
(4,051 Views)
Interesting.
But I have a lot of doubts about a product where the vendor spells at least 3 words wrong on its website.Smiley Wink
Vehicals?
Diatance?
Trough?
One hand held device with a dozen buttons controlling an enitre car factory?  That is a miracle device!
Message Edited by Ravens Fan on 10-30-2008 04:51 PM
(4,035 Views)
Hi all,
What about a PDA device? It wouldn't be the best for harsh environments, but they can come with holsters, which can be professional. You're right, a Wii mote is necessarily the best tool for the job, and you probably would miss out on the joy of using its gyro's if you're just using the buttons. 🙂 Besides that, you probably don't want to by an RF module, which would be extremely expensive for just that application.
You could also use a 6in touch panel and perhaps get wireless connectivity by using the USB port with a plug and play antenna. Maybe another vendor makes a TPC with wireless connectivity. But that's just the PDA anyway, so I think the PDA is the way to go. I'd look into options there and let us know if you have any more questions.
Let me know if that helps.
Dan Richards
Certified LabVIEW Developer
(3,997 Views)
