Problem with Continuous Swept-Sine THD and limit testing
Hello ,
I am testing a loudspeaker using NI PXI 4461 and "sound and vibration " suite  .
The loudspeaker in linked to the output of the card that is generating a continuos sine sweep  ( 20hz to 20Khz) and getting the signal back through a microphone that is linked to the input of the 4461 . Sampling rate : 51.2KHz ; Delay :108
I used the VI example " Continuous Swept-Sine Measurements (DAQmx) "  and modified it a little bit .
I want to compare the THD values calculated with the "SV Continuous Swept-Sine THD VI" with golden values that have already been measured .
My problem is that when I want to use the SV limit testing VI , to compare THD to the golden values , the limit testing VI needs to have the same X-axis ( frequency) for the THD and for the golden values , which is impossible because there is almost 20000 frequency component of the THD and the frequencies are very bizarre as you will see in the photo ( I can't use searching for my values in the THD array ,) .
So , Is there a solution  so I can compare the THD with my values ?  and how does the "SV Continuous Swept-Sine THD VI" work ?
I am sorry for the messy code . ( LV 2018 )
(2,918 Views)
Hi!
I have some questions:
1. Can you clarify what do you use to measure the golden values?
2. How many golden values do you have?
3. Is there a continuous spacing between the frequencies of the golden values?
Also, do you see any value on comparing the THD of values at different fundamental frequencies?
Best,
Gaheel17
(2,874 Views)
Hello  and thank you for your response  :
1 - I do not know , they were just sent to me, They were  propably calculated while testing golden loudspeakers .
2- 30
3- The frequencies of the golden values were the result of 1/3 octave of the input signal . You can find the frequencies of the golden values in the image "golden" that  I attached to the first post .
Yes , I think there is a value to know how the loudspeaker behaves regarding distorsion , for the whole frequency range ( 20 to 20Khz ) . I am new to acoustics , the opinion of an expert would be more efficient .
Best regards .
(2,867 Views)
