There's a problem to Use ALTER Query to Rename the Table
Hi.
I was trying to rename my table by query.
So I found 'ALTER TABLE old_table_name RENAME TO new_table_name;' query on the internet.
But it cause error.
I try other functions like
ALTER TABLE name DROP [COLUMN] column_name
ALTER TABLE name ADD COLUMNS
and it work fine.
I don't know why I can't change my Table by 'ALTER' statement.
Is there anybody know the reason?
Message 1 of 8
(4,634 Views)
Try sp_rename
Message 2 of 8
(4,583 Views)
It would be useful to know the error...
What database are you using? Apparently MySQL uses a different syntax.
Message 3 of 8
(4,580 Views)
I’m working with Access.
Message 4 of 8
(4,570 Views)
https://docs.microsoft.com/en-us/office/client-developer/access/desktop-database-reference/alter-tab...
Note
The Microsoft Access database engine does not support the use of ALTER TABLE, or any of the data definition language (DDL) statements, with non-Microsoft Access databases. Use the DAO Create methods instead."
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 8
(4,565 Views)
You can Select everything and drop it into a new table, then drop the old, that'd effectively be a rename.
SELECT *
INTO [acecodetable].['PSCLineReason']
FROM [acecodetable].['15_PSCLineReason'];
DROP [acecodetable].['15_PSCLineReason']
/Y
Qestit Systems
Message 6 of 8
(4,559 Views)
So there No way to Rename the Table by ALTER Query.
Thanks guys
Message 8 of 8
(4,525 Views)
