Problem with DAQmx Physical Channel control
Is your hardware detected in MAX ?
Did you try to use MAX Front Test Panels ? If it is working fine, then start again you project from scratch... because i don't know. Maybe some LabVIEW guru could help.
Message 11 of 17
(2,254 Views)
Hardware is detected in MAX.
MAX Testpanels are working.
Starting the project from scratch results in the same behaviour.
It seems to be some 'integration error' of the DAQmx drivers to projects.
I also found out, that I can not create a new DAQmx physical channel or task within the project (by right click > New > NI-DAQmx Channel)
When I try so, nothing happens at all. It is like I didn't even click the item.
Thank you, vincent. Maybe someone else can help me.
I really don't want to reinstall all NI drivers and software - it takes too long.
Message 12 of 17
(2,251 Views)
I also have the same problem with you, you solved now?
thanks!
Message 13 of 17
(2,214 Views)
I have, several times, had MAX/DAQmx stop working, often when installing a new version of LabVIEW or installing an update from NI.
What (as far as I remember) always fixed it for me was to do a Repair.  Open Control Panel, Programs and Features, find NI Software, find DAQmx, and choose "Repair".  Note that you need to have installation media (or the downloaded installation files, usually in C:\NI Downloads) available.  Yes, it does take some time (usually less than an hour), but it is much shorter than either a "Reformat the Hard Drive" (i.e. "Start Over") or "Remove all NI Software/Reinstall all NI Products".  When you are finished, be sure to reboot and see if you've fixed the problem.  If not, you may have to Repair a few other things ...
Bob Schor
Message 14 of 17
(2,208 Views)
Hi :
    I  have the same error: Error -229771 occurred at DAQmx Create Channel.
    did you solved it?   I ned your help ! thanks!
Message 15 of 17
(2,194 Views)
I'm having the exact same problem! Inside project, nothing works; sigle vi's works fine...
Message 16 of 17
(2,098 Views)
Sorry to hear that you have the same problem as a six-month-old post.  I would be able to "see" your issue from the documentation you have attached (a compressed file of the Folder containing your LabVIEW Project and all of your VIs), but for some reason, my PC fails to open this attachment.
I recommend that you abandon this post, start a new one, describe your problem as carefully as you can, and reattach all of the code that you have been developing so that we can try to help you figure out how to get it to work.
Bob Schor
Message 17 of 17
(2,085 Views)
