Problem with Event structure
Hallo
I am expecting from my LV if I press the  buttons , a new window will be opened and the corresponding events will be activated.
the problem is , wenn I press the button , the SubVI will be activated without opening a new window and therefore I can't continue running the prog.
please take a look at the LV and tell me where is the problem
Thank you in advance
 Toni
LV 8.5
(2,795 Views)
Right click on the SubVI that you placed on the block diagram, select "SubVI Node Setup ..." and check "Show Front Panel When Called" and "Close Afterwards if Originally Closed"
(2,788 Views)
