fpga
I do test labview fpga, work with the spartan 3rd starter kit board.
I have a small program and compile perfectly but after compiling I see this error
Screen (compile ok)
(3,746 Views)
and This the error :
(3,745 Views)
Hi micman
I need much mor details about your issue. Fist i notice that this error code (2147483648) doesn't seem a error code but, like the error box says, you might have wired a number that is not an error. In fact this number also represents the maximum number of interactions that a loop cycle can reach. Therefore i ask you if you can relate this comment with your issue. I suggest you to check the error wiring throw the program and to perform a debugging procedure to locate the critical point in during vi running.
regards
Matteo
(3,586 Views)
Thank you for having responded.
Send the source code It's simple program for example (use spartan 3e)
(3,551 Views)
Now work!!!!!! oh yeah Smiley Wink The problem is the not correrct driver install in usb jtag
(3,403 Views)
