Problem with Labview 6.1 exe application under Win98
I have a problem with an application compiled with Labview 6.1 running
under Windows 98. After approx 1 month of service, the PC is totally
unstable and slow. There was no problem when the application was
compiled with Labview 6i
This application reads many analog and digitals channels via NI-DAQ and
has the HTTPServer built-in.
Does anyone have the same problem? I know that Win98 is not a good
choice for a 24h/24 data acquisition application... but it worked with
labwiew 6i....
Thanks in advance for your answers and best regards
Antoine Jacot
Dev. engineer
University of applied sciences (EIAJ)
CH-2400 Le Locle
Switzerland
(2,586 Views)
Hello Antoine
I suppose, you just already installed the NiDaq upgrade (and LV patch) in accordance with your current version of Labview 6.1, if you didn't, check out this:
http://digital.ni.com/softlib.nsf/websearch/50F49E43A22C0D2186256BF3006B9A96?opendocument&node=132070_US
I just recently finished some development using the same configuration that you have described, and i had excellent performance, instead the other versions of Labview, if you want, you can give me more details about your problem.
JFT
systems engineer
ETT Ltda
Valparaiso - Chile.
(2,586 Views)
