Problem with Mixed Signal Graph cursor LV 2013
 I'm trying to create a feature that puts the location of the cursor to a specific point on the x axis. When I'm not sending the value, the cursor behaves normally. When I send the value (even when using a constant) the cursor will keep oscillating between previous position and position entered in property node.
This doesn't happen when using an XY graph, only with a multi signal. Is this a glitch or am I doing something patently wrong? Below is a snippet from my BD.
Message 1 of 14
(5,395 Views)
I forgot something, The cursor legend retains the values from the previous position, it does not update to the location I put into the prop node.
Message 2 of 14
(5,388 Views)
Do you by any chance have the cursor to snap to a plot. That might cause it to move temporarily and then snap back. Why do you keep setting the same things over and over again (cursor visible, for example). Stop doing that to see if it makes a difference too.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 14
(5,387 Views)
Mike,
I'm not sure what you mean by "snap to a plot".
Removing the redundancies doesn't help. Sorry about the mess. I didn't feel like making it pretty for y'all, after all, it's Friday 😉
Message 4 of 14
(5,381 Views)
If you right click on the cursor one of the options you can set is whether it snaps to a particular plot, a particular point or neither.
Mike...
LabVIEW Champion
Message 5 of 14
(5,377 Views)
OK, I know what you mean; I just tried various combos with no luck 😕
Message 6 of 14
(5,369 Views)
Can you create a simple subset of your app that exhibits the effect?
Mike...
LabVIEW Champion
Message 7 of 14
(5,351 Views)
Sure, I'll post it in a bit
Message 8 of 14
(5,318 Views)
One other thing, it only does it with the cursor set to Multi-Plot, it works okay with Single Plot.
Message 9 of 14
(5,314 Views)
Here is a truncated version of the problem, essentially I'm taking data from a csv file and graphing it. The feature finds the row position of where a fault occurs, and allows the user to go directly to that place in the data.
Even in this version I still have the issue. The cursor keeps wanting to go to its previous location.
Any help is welcome.
Rick Speaker
Message 10 of 14
(5,304 Views)
