Problem with Mixed Signal Graph cursor LV 2013
Hello Rick,
I believe I have found that the issue is about the cursor mode being used. I have uploaded your VI with the addition of a cursor mode control. You will see that the VI functions as expected for cursor modes 0 (free) and 1 (single plot) but does the same flicker you are experiencing for cursor mode 2 (multi-plot). I will investigate further into why this is but for the meantime, I would recommend setting a cursor mode of 0 or 1 to solve the issue.
Thanks!
Collin D.
Software Product Manager
Message 11 of 14
(1,216 Views)
Thank you Collin,
The reason I want to use the Multi-plot option is to read all values. I am interested to see where this goes. Thank you for looking into it. I will look at the VI you sent.
Rick
Message 12 of 14
(1,204 Views)
Hey Collin,
The problem seems to resolve itself by changing from mode 2 to 1. Is this just an issue with the MS graph?
Message 13 of 14
(1,153 Views)
Accepted by topic author Speaks
Hello Speaks,
Indeed, the issue seems to be related to the Mixed Signal Graph. A Corrective Action Request may be filed to investigate the issue. In the mean-time, using a cursor mode of 0 or 1 should be an adequate work-around.
j_bou
Message 14 of 14
(1,136 Views)
