Problem with Scale object with pane in tab control .
Hi
My problem is that i cannot select "Scale object with pane" for the controls inside a Tab control if the Tab control "Scale object with pane" is turned on. I want both the Tab control and the controls inside to be scaled, for instance an Waveform graph or an textbox  when i resize my main window.
Thank you.
(3,083 Views)
You can set all objects to scale with the Window, under VI Properties > Window Size, if that helps.
Beyond that, I don't think you can scale automatically controls inside a Tab Control.
If you want to code it yourself, you can, but this is just another reason that Tab Controls are a little frustrating.
GCentral
(3,061 Views)
I can't do that VI Properties > Window Size... because i have many pane panels In my situation so i can't do it " in Applies only to single pane panels "
(3,056 Views)
Sorry - didn't notice you'd attached a VI. However, that just brings me to my second point, which is I'm sorry, I don't think you can unless you code it yourself ^^
GCentral
(3,052 Views)
