Problem with TDMS Logging
Hello. Im running a sensor simulatuion code with a random number generator. The VI is running on my laptop. Im using LabVIEW 2013. I want to log the data and store it on my PC (anywhere will do). Im trying to write it as a TDMS file but I keep receiving an error -2501 on TDMS close. Could somebody please help me out.
Thanks 🙂
VI Attached below
(3,585 Views)
Accepted by deepen_solanki
You are trying to close the same tdms file two times, why are you doing that?
Try to serialize your write to the tdms so that you do not write in parallel in this simple program.
(3,571 Views)
Actually, your part about closing the same file twice was very helpful ! Thanks a lot, i figured it out 🙂
(3,554 Views)
