Problem with Waveform Chart updating
Hi!
I have written a LabVIEW project for 8510.
I have a problem with the waveform chart not updating the data incoming to it.
that is, Y axis does not update according to 8510 display format.
May you help me?
Message 1 of 14
(5,405 Views)
You need to attach more than that.  The .lvproj is only a top-level file that describes the VI's that make up the project.  It is not the VI's themselves.
Message 2 of 14
(5,398 Views)
sorry
I atached agaim all VI.
Message 3 of 14
(5,395 Views)
I can't see any waveform chart in the VI that your shared...!!!
Anyways, if your waveform chart gonna be attached to "Trace Array Output 2" indicator (of the VI that you shared), then in that case you may also need to tell, whether you're getting desired output in this indicator or not...??
If not, then share the string resulted from "VISA Read".
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 4 of 14
(5,384 Views)
my waveform at trace array output 2 is the same as 8510 network display, but Y and X axis are not frequency (in Hz unit) and power level ( in dB unit). that is, Y axis is the range of -100 dB to 0dB in real ( in 8510 network display) but Y axis at this output is the range of 0.00001 to 1.
why??
Message 5 of 14
(5,362 Views)
It seems to me that you need to convert the numbers from .00000001 to 1 into the dB equivalents using ratios and the log function.
Message 6 of 14
(5,346 Views)
Try this:
http://zone.ni.com/reference/en-XX/help/371361J-01/lvanls/spectrum_unit_conversion/
If you don't want to use inbuilt VI, and want to make your own comversion logic... You may want to refer:
http://www.rapidtables.com/convert/power/dBm_to_Watt.htm
Message 7 of 14
(5,340 Views)
Hi
I Try this:
Apparently, The vertical axis scale in my wavegraph is corrected, but the horizontal axis is Time or Point (samples), How do I change it to frequency?
thanks
Message 8 of 14
(5,309 Views)
Do you want to change the label???
1. Just right clicl your graph
2. in the properties window go to 'Scales' tab
3. select the Axis, and change the name.
Is this the solution regarding your issue....
Or
do you want to change the domain from Time or Frequency...??
Message 9 of 14
(5,291 Views)
I want to change domain from time to frequency
Message 10 of 14
(5,276 Views)
