Problem with Waveform Chart updating
Hi
I sacled X axis (number of points for example 201) to frequency domain by using of span frequency and start/stop of frequency.
thank you all for your help
Message 11 of 14
(933 Views)
Hi
I'm faced with another problem!
I used "OUTPMARK" command. that is, I write the command and then read output.
Before this command, I used "MARK1 17 GHz;" command and then write "OUTPMARK".
The OUTPMARK; statement always transfers two values in standard ASCII format. As shown
in Table 13-1, the values depend upon the currently selected display format. Two values are
output in every display format, but for Cartesian displays the second value is zero.
My output for example was "8.12" instead of "81.2".
why?
Message 12 of 14
(915 Views)
Please upload your VI..
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 13 of 14
(907 Views)
hi
Message 14 of 14
(896 Views)
