Problem with Yokogawa DL750 USB comunication with labview
i have recently download labview drivers for Yokogawa DL750 and i want to comunicate it with labview via USB but it´s impossible for me. Can anyone orientate me about the way to make this communication? I am a novice with labview. Attached there is a image with the configuration i am trying( it´s one of the examples for YOKDL750) Thank you very much.
Regards
(4,408 Views)
Hi arquito,
LabVIEW supports some instruments from Yokogawa like the oscilloscope DL9240L using API functions for example.
When you download the driver for the instrument the new functions becomes available in LabVIEW under the Function menu \ Instrument I/O \ Instr Driver...
If it doesn't show please confirm that the menu (mnu files) where created by the installation of the driver under:  labview\instr.lib\... and that the VISA version is reflecting what the maker document recommends.
For the DL750 ScopeCorder the specification refer to a GPIB connection, not USB;
You might want to confirm that you have the proper driver and contact Yokogawa directly as NI doesn't support the driver for this device corresponding to the information below:
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=1880   -> Go to Driver Page!
If you need any more support to program with the API, or searching for contacts please ask me.
(4,327 Views)
Hi Arquito,
Did you ever get to use the DL750 to obtain measurements using labview? I have the drivers, I can communicate with it but I am getting a number of errors when trying to use the driver examples to try it out. If you did, please let me know how you went about it.
Tickle
(3,708 Views)
