how can we get an image of selected area of the front panel
i am plotting some graphs and want a group photo of all those in one shot is it possible????
n i want to get the graph coordinates on the mouse click.....
i.e when i click on the graph at any place the values corresponding to it must be retrieved. how do we do that,,...
i have tried with the labview help but didnt get any help
help please????????
(4,200 Views)
Here's a start.  This will get the front panel image and display it as a picture indicator.
You could use an event structure to capture the mouse clicks on the picture control to set the image area.  Then using the mouse coordinates (referenced from the image coordinates), you can get the image subset "Get Image Subset.vi".
Message Edited by vt92 on 04-20-2010 08:30 AM
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(4,182 Views)
(4,177 Views)
facing this problem while designing a project..
Error 1003 occurred at AB_Application.lvclass:Open_Top_Level_VIs.vi -> AB_Build.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi -> AB_UI_FRAMEWORK.vi -> AB_CreateNewWizard_Invoke_CORE.vi -> EBUIP_CreateNewWizard_Invoke.vi -> EBUIP_CreateNewWizard_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located.  Open the VI in LabVIEW using File>>Open and verify that it is runnable.
(4,027 Views)
Is this related to this thread? If not start a new one.
(3,995 Views)
installation is not supporting the windows 07 starter version ans is asking me to contact the documentation of the operating system.
as the result also the intaller created for the application of my project is also not able to install in the system please help.
(3,916 Views)
dear all
u want to transfer some data or file on my mail or some website, i tried to do that but did not get the success.
need some help.
(3,875 Views)
