Problem with counting number of clic with initialize mouse vi
I want the vi stops when the user clics several times with the mouse. I use initialize mouse vi instead of event structure for other reasons (I can't use it).
I intented to count the number of clics and when this number of clics occur, the vi stop. But the vi don't work, it stops at the first clic although when i highlight execution it seems to work as I want.
I send here the vi.
If someone could help me, thanks in advance.
(2,733 Views)
The problem is the execution time, if you push the mouse button your program will execute number of times before you lose the button agian. Even if you push it realy fast.
I made some changes to your code there i wait until button is released befor continuing.
Regards
/Thomas
(2,730 Views)
hi there
i'm just curious: why can't you use the event structure?
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,720 Views)
Thanks for your solution, I see now where is the problem.
(2,713 Views)
Chrisger, it is because I use sequence structure with many times I have to require the user to clic on the front panel before advancing to the next sequence. In this case I can't use many event structures.
Message Edité par nousome le 09-14-2006 10:34 AM
(2,712 Views)
