Problem with cursors
I have a problem with cursors. I use a property node to set their positions x and y. The problem is that the cursors don't go to that position which I write. For example if I write 1480 to Cursor.PosX it sets the cursor's position to 1372. Same to Y. See my attachment. There are no other property nodes writing positions than that in the picture.
BR,
Jick
(4,166 Views)
Accepted by topic author Jick
Changing them to free cursors helps but I am still wondering what might cause the behavior like that with Single-Plot cursor?!
Jick
(4,157 Views)
hi jick,
  The problem is there because there might be no value of 1480,so it is rounding to near value which is normally the case in single plot...IN free drag mode,it is not such a limitation.
Thanks and regards,
srikrishnaNF
Srikrishna
(4,147 Views)
Thanks for your reply,
Ok. This kind of rounding sounds still strange...
BR,
Jick
(4,131 Views)
How is it strange? If, for example, you have the values 3 and 5 in your y array, you have the cursor locked to the plot, and you tell it to snap to a value of 4, it simply cannot lock to a value that does not exist. When you make it a free cursor, it does not know or care about actual values in the y array
(4,099 Views)
Yes, I understand the theory of rounding. It was strange because I didn't understand why there is such a feature which rounds wanted cursor position. Fortunately I found the free cursor!
Jick
(4,073 Views)
