08-06-2007 08:30 AM
08-06-2007 08:52 AM
08-06-2007 08:55 AM - edited 08-06-2007 08:55 AM
Message Edited by TonP on 08-06-2007 03:55 PM
08-07-2007 05:22 AM
Thanks Dennis Knutson and TonP for your replies. I couldn't try this code with my DAQ card yet, but I don't expect any problem. It works fine with the simulated signal perfectly and solves my problem. But I have a question. What would be a solution, if I had wanted to configure one AI channel as RSE and the other channel as differential. Now we use differential configuration common for both channels, in this case we couldn't.
Thanks for your concern.
Ahmet
08-07-2007 06:03 AM
08-07-2007 06:51 AM - edited 08-07-2007 06:51 AM
If you want different terminal configurations for the channels, then you use separate DAQmx Create Channel functions.
Message Edited by Dennis Knutson on 08-07-2007 05:52 AM
