Problem with database connectivity in run time system
Hello all,
I am using database connectivity tool kit in my application (labview 2011).
Every thing runs fine on my system (developement system).
When I install my application on any other PC the path for my data base is not found.
i dont want to keep a constant or fixed path for my database.  I want that the database path should be automatically buit where ever the app is installed.  Please suggest how to get path programatically.
Message 1 of 26
(5,354 Views)
What is database you use?
Message 2 of 26
(5,352 Views)
ms access (.mdb file format)
I am using .udl for database connectivity
microsoft jet 4.0 OLE DB
Message 3 of 26
(5,343 Views)
Put one indicator and see what path it is selecting. You dont need udl file to use mdb file
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 4 of 26
(5,338 Views)
Dear Ranjit,
Can you help me out with an example or some related link.
I tried but it is not working without udl.
Message 5 of 26
(5,333 Views)
Extract the attachement. Run the VI and let me know
--Ranjeet
Message 6 of 26
(5,328 Views)
Its working ... wow!!!
Thank you Ranjeet
Message 7 of 26
(5,304 Views)
You are most welcome.......SKY_THE_CHALLANGE.....
--Ranjeet
Message 8 of 26
(5,287 Views)
hello ranjit,
microsoft jet oledb4.0 is not available in windows 7.....
can you suggest some option or how to get it in windows 7 pc
Message 9 of 26
(5,217 Views)
What are you talking about, I have a JET application that has been running for weeks on a Windows7 machine.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 10 of 26
(5,202 Views)
