Problem with dsc shared shared variables and error 1950679023
I'm having trouble using shared variables on my laptop PC (with Windows XP) using Labview 8.2 and DSC.   I've set up a simple project with one VI and one shared variable library.  In the VI, I have  a while loop that writes a number from a front panel control to the shared variable.  Another loop running in parallel reads the shared variable and displays to an indicator on the front panel.   The VI resides on my PC (no remote targets). This program executes just fine on my desk top PC; however I get the following error codes out of the shared variable nodes when I run the project and VI on my laptop for the write and read, respectively: ni_tagger_lv_Write 180121604 ni_tagger_lv_Read -1950679023 I've tried to manually deploy the shared variable library without success. The NI knowledge base  and other entries on this forum suggested that the Windows firewall should be disabled for a quick fix, however, the firewall was already disabled on my lap top. I didn't see any entries regarding the 180121604 error code.
Any suggestions would be appreciated.
(9,580 Views)
The problem has mysteriously gone away.  For about the 10th time, I manually deployed the share variable library, and it started to work properly.
(9,501 Views)
Ky:
Please post again if you run into this issue again.
Rudi N.
(9,368 Views)
