Problem with .exe after creation in Labview Application builder
I just made an .exe using Labviews application bulider however when I run the executable it does not function properly even though the source code runs fine.  The prgram is a basic data aquistion program that is simply taking inputs from Fieldpoint and displaying them.
I have attached a simplified version of the project that highlights the problem. When the exe presure readerv2 is run the signal aquired from Fieldpoint is 0 and subsequently the pressure displayed is -250.
Whats up ?
(2,995 Views)
First,  the .lvproj you attached doesn't tell us anything.  It is just a file that defines what files are a part of your project, it isn't the project itself.
Second, where is the .exe not running properly.  Is it on the same PC that it was developed on and includes LabVIEW?  Or is it on another PC that never had LabVIEW?
(2,981 Views)
Here is the executable along with the rest of the folder that it is contained in as well as the .vi it was derived from.
The program does not run on either the original computer or another machine.
(2,954 Views)
