labview
hallo zusammen
habe ein kleine frage
weisst jemand warum kann ich nicht die beide diagramme in die letzte signalverlaufsdiagramm  3 sehen.
noch eine frage wie kann man eine Signal erstellen,die  die werte von eine Excel Datei  lesen???
vielen dank
(3,805 Views)
hallo,
 try to write english questions...
Alles gute
Tinnitus
Message Edité par tinnitus le 12-11-2008 10:49 AM
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,783 Views)
You should really start using a catchy title for your questions. Every question you post here is titled "labview", which (for a LabVIEW forum !) applies to probably every single thread and is thus not informative at all. Please put some keywords from your question in the title.
 1. Your third graph will update once both inner while loops have finished. This is due to the magic of dataflow. 🙂
(You should really use latch action buttons to terminate loops and set the condition to "stop if true". Much cleaner!)
2. The example finder has some examples for dealing with excel files.
(3,779 Views)
hello together  here is my answer in englisch 🙂
have a small wonder
anyone know why I can not both charts in the last waveform see Diagram 3.
still a wonder how you can create a signal that the values of an Excel file to read?
thank you very much
(3,742 Views)
Your question regarding the graph update has already been answered by altenbach - dataflow.
Your other question about saving the data so that Excel can read it: As mentioned you can use ActiveX to write the values directly into an Excel file, or (easier) you can use the Write to Spreadsheet File function. This will save the values into a tab-delimited text file that you can open in Excel.  Keep in mind that you will need to extract the array of values from the waveform datatype.
(3,710 Views)
