Problem with ramp input
In the vi attached above the output 0-100 has all the values. All you need to do is just play around with the array manupulation.
Message 11 of 22
(2,900 Views)
Hey can u just see this vi.. i am half way done..
Thanks for the help.
Message 12 of 22
(2,894 Views)
Can you post it for lv 8.0?
Message 13 of 22
(2,891 Views)
VI in LV 8.0
Message 14 of 22
(2,888 Views)
Dont you think so your code is taking tooo long to get completely executed? The only thing that is going fine is you see the graph getting updated since you have it inside the while loop itself. But the time taken is equally important right?
Message 15 of 22
(2,881 Views)
If i make it fast my device may not react properly. I should give some time. I guess the time is perfect but i am not getting complete ramp cycle.   😞
Message 16 of 22
(2,861 Views)
R u trying to get the data or feed this data?
Message 17 of 22
(2,849 Views)
Accepted by kaush
Your vi modified
Message 18 of 22
(2,848 Views)
Solved?
Message 19 of 22
(2,841 Views)
Its perfect.. Thanks a lot 🙂  I am still learning LV..
Message 20 of 22
(2,834 Views)
