‎01-10-2007 02:11 PM
‎01-10-2007 02:16 PM
With error code 1, you have two possible causes of the error. The first possibility is the invalid invalid parameter and the second possiblilty is the GPIB error. Since you are not using GPIB and the error occured at a property node, my guess is that you have an invalid parameter for the property node. ![]()
What is the property node and what are are the values you are using?
‎01-10-2007 02:25 PM
‎06-12-2007 02:07 PM
‎06-13-2007 06:41 PM
‎06-14-2007 11:10 AM
