Problem with serial read/write
Hello all,
I am not sure if this belongs here or on one of the hardware boards, but I thought I would start here.
I have two devices which I am currently trying to talk to via serial ports on a PXI chassis under real time.  In both instances, I have serial software that appears to be working fine when I use the serial port on the controller (i.e. COM1).  Now, I have two cards that I have been using on two different systems to talk to these devices - 8430/2 and the 8430/4.  In both instances, when I use these cards, it seems I have periodic delays in response by the devices when using the same code that I use when talking through the controller serial port (i.e. I get a time out on the attempt to read, error code -1073807339).  I have tried swapping the cards with spares but I get the same issue.  I can handle the delays by retransmitting the command, but this ultimately destroys the determinism of the system given that the delay can create a pause of up to about 2 seconds.  I have tried changing the buffer size but I seem to get the same problem.  Does anyone have any thoughts as to what might be going on?
Cheers, Matt
(3,085 Views)
Hello Matt, hope you are doing great.
Seems to me what you are experiencing is a timeout error.
You can check this and let us know if it worked afterwards,
Warm regards Matt.
Luis Martinez.
Applications Engineer.
National Instruments.
(3,047 Views)
Accepted by topic author cirrusio
Thanks, Luis.  Indeed, one of the errors being thrown was a timeout error (the other was thrown by one of the devices indicating that it did not understand the command sent).  However, the problem was not that I was getting a timeout, but rather that I was getting an error on one platform and not on another.  But, it seems that I have solved my problem - I simply set the VISA Write function I/O mode to synchronous and this seemed to fix the issue that I was having.
Cheers, Matt
(3,022 Views)
