Problem with string control..
chrisger wrote:
try to place the LF in FRONT of the text..
That's what i did in my test. Then it seems to get better.
chrisger wrote:
Oh yes, and make sur eto first write the output an THEN to set the scroll position. See attachment.
Neither of these will have any discernible impact. At least, I saw none. Perhaps deferring panel updates may help, but I doubt it, and unfortunately I don't have time right now to play with it.
Message 11 of 13
(1,297 Views)
JayRam, see attachment. Is this the blinking in the upper indicator you have mentioned?
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 12 of 13
(1,288 Views)
Hello.. 🙂
If this is what you are talking as blinking... Then why don't you slow down a lil bit using time & dialog...?
Message 13 of 13
(1,268 Views)
