Problem with subpanel
Hi I'm opening a VI suppose 'A' in a subpanel.After an UI event a sub VI 'B' opens.At this point the 'A' VI's front panel should hide and when my sub VI 'B'finishes its operation and closes ,the 'A' VI's front panel should again return to its standard size.
In the block diagram of 'A' Vi i've used the front panel property 'Front panel State'.But the VI 'A' doesnt hide when i use it in a subpanel.
What might be the problem??
(2,570 Views)
Hi swanthi,
you have to remove it first from the subpanel.
Mike
(2,551 Views)
