Problem with variant block
Hi nutty,
what is a "structure"?
Message 11 of 17
(2,107 Views)
nutty_1988 wrote:
I agree with you, infact i have used that block.
The problem is... When, instead of a bool or a number, i receive a structure... how can i make to manage it?!?!
What do you mean by structure?
Message 12 of 17
(2,101 Views)
Structure is a sort of cluster...
For example... Consider a variable called "machine".
Inside "machine" variable" you could have another variable called "command". Inside command there are two variables, for example start and stop that are two booleans.
The hierarchy could be like this
machine
             command
                              start
                              stop
 How can i manage this?!
Message 13 of 17
(2,095 Views)
Hi nutty,
can you show a FP element depicting your "structure"?
What is "sort of a cluster"? Is it a cluster - or is it something different?
Message 14 of 17
(2,091 Views)
Yes... Is a cluster.
If i receive a string like this "FALSE;FALSE;0" how can i separate each of this in a correct manner?! I would want separate them in two bool and one numeric...
 In each word... i would like to convert the string in a cluster...
Message 15 of 17
(2,086 Views)
Hi nutty,
when you receive a string like "value ; value ; value" you use SpreadsheetStringToArray with a separator of ";" to get an array of strings.
Then you index each string as needed…
Message 16 of 17
(2,084 Views)
GREAT!!
I will try!!
Message 17 of 17
(2,080 Views)
