Problem with waveform chart: time scale does not show time correctly
Hi Johannes,
just read the context help for the graph: multiplot requires 2D data or array of waveforms...
Message 11 of 17
(2,914 Views)
I started a new thread for that problem.
Is that ok? I don't know...
Here it is...
http://forums.ni.com/ni/board/message?board.id=170&thread.id=447862
Message Edited by johanneshoer on 10-14-2009 08:46 AM
Greetings Johannes
Using LabVIEW 7.1 and 2009 recently
Message 12 of 17
(2,909 Views)
Hi Johannes,
I would prefer to stay in this thread as it (even with changed question) still handles the same routine. This way all others will have all needed information in one place and can follow the evolution of your vi easily Smiley Wink
Message 13 of 17
(2,905 Views)
all right. I understand.
I will take care if it the next time.
Greetings Johannes
Message 14 of 17
(2,903 Views)
I'm working on extracting temperature values and timestamps from an sms text message polled from my gsm. Could you tell me how i could plot an array of timestamps against temperature in a waveform displayed on labview.
Hamid.
Message 15 of 17
(2,415 Views)
How about starting your own thread instead of hitch hicking somebody else's thread?
Greetings Johannes
Message 16 of 17
(2,409 Views)
Hi Hamid,
why do you hijack an old thread instead of opening your own? What have you tried so far?
Plotting temps vs timestamps is as easy as this:
Message 17 of 17
(2,408 Views)
