Problem with waveform chart
I use the waveform chart .
what i do ?
Message 11 of 19
(2,922 Views)
I found following vi in this address :
decibel.ni.com
can explain me about this ?
Message 12 of 19
(2,920 Views)
He is trying to display the entire history of the chart. I tend to let my chart to have a higher resolution and allow the user scroll through the data.
What is your data rate for the chart? If it is 1 eversecond, then the multiplier should be 1, 10 times a second, .1, etc...
Message 13 of 19
(2,916 Views)
Excuse me .
Can you attach a sample vi through it Can be control  X-axis of a chart ?
i wrok by labview2010.
Message 14 of 19
(2,913 Views)
This will display in units on the bottom.
Message 15 of 19
(2,903 Views)
Dear friend.
Please save your vi for v10.0
Message 16 of 19
(2,899 Views)
I only have 11.0 installed. You will need someone on the list to onvert it.
Message 17 of 19
(2,894 Views)
Thank you very much.
You can go to file menu and click save for previous version and select .
Message 18 of 19
(2,890 Views)
here is 10.0
Message 19 of 19
(2,888 Views)
